HMIN_outputblock_write()
Writes an outputblock to HyperMesh.
void HMIN_ outputblock _write(HM_entityidtype id, char * name, char * entitytypename);
HyperMesh hminlib Function
id
The ID of the outputblock.
name
The name of the outputblock.
entitytypename
The entity type that the outputblock collects. This can be set to elements, nodes, components, systems, materials, or groups.
HMIN_outputblock_writeid() must be called after using HMIN_outputblockwrite() to put individual entities into the outputblock.
None.
