HMIN_set_write()
Writes a set to HyperMesh.
void HMIN_set_write(HM_entityidtype id, char * name, int color, char * entitytypename);
HyperMesh hminlib Function
id
The ID of the set.
name
The name of the set.
color
The color to be assigned to the set.
entitytypename
The entity type that the set collects. This can be set to nodes, elements, components, sets, materials, or properties.
HMIN_set_writeid() must be called after using HMIN_set_write() to put individual entities into the set.
None.
