HMIN_startsurf()
Signals the beginning of a surface.
void HMIN_startsurf(HM_entityidtype id, double tolerance, double ptolerance, HM_entityidtype componentid);
HyperMesh hminlib Function
id
The ID of the surface.
tolerance
The tolerance to which you have created the surface. Two points less than this distance apart are considered the same point.
ptolerance
The tolerance for the parameter space on this surface. Two points less than this distance apart in parameter space are considered the same point.
componentid
The ID of the collector where the surface should be placed.
None.
