HMIN_table_column_bool_write()
Writes bool column data to a table.
void HMIN_table_column_bool_write(char* column_array, unsigned int array_size, unsigned int column_index);
HyperMesh hminlib Function
Writes bool column data to a table. This must be preceded by a call to HMIN_table_write().
column_array
The bool array containing the column data.
array_size
The size (number of rows) in the column array.
index
The index of the column in the table.
Incorrect usage results in an FE-input error.
Version History
11.0
