HMIN_tag_write()
Writes a tag entity to the database.
void HMIN_tag_write(HM_entityidtype id, HM_entityidtype entity_id, HM_entitytype entity_type, int color, char *label, char *body);
HyperMesh hminlib Function
This function writes a tag entity to the database.
id
The ID of the tag.
entity_id
The ID of the entity to attach the tag to.
entity_type
The type of entity to attach the tag to.
color
The color of the tag. Valid values are 1-64.
label
The string to assign as the tag label.
body
The string to assign as the tag body.
None.
