HMIN_transform_write()
Allows systems, loads, or nodes to be transformed to the global coordinate system, based on the local coordinate system.
void HMIN_transform_write(HM_entitytype type, HM_entityidtype id, HM_entityidtype systemid);
HyperMesh hminlib Function
type
The type of entity to be transformed, systems, loads, or nodes.
id
The ID of the type.
systemid
The ID of the system into which the entities are transformed.
This function allows entities defined in a local coordinate system to be passed to HyperMesh. HyperMesh can then do transformations on those entities in the global coordinate system.
None.
