HMIN_vector_write()
Writes a vector entity to HyperMesh.
void HMIN_vector_write(HM_entityidtype id, HM_entityidtype basenode, double axis[3], double magnitude, HM_entityidtype collectorid)
HyperMesh hminlib Function
id
The ID of the vector.
basenode
The ID of the node to which the vector is attached.
axis[3]
The direction components of the vector [i,j,k].
magnitude
The magnitude of the vector.
collectorid
The ID of the vector collector.
systemid
The ID of the system associated with the vector.
None.
