pltIVector GetParameterizationID
Gives the string corresponding the name and number of the datasource (vector).
pltIVector_handle GetParameterizationID
HyperWorks Tcl Query
This command returns the string having complete ID of just the datasource (vector), which can point out the datasource (vector) if the page and window are known. It essentially gives the curve name and the type of datasource (vector).
Assuming that first page and first window contains one and only curve in plot client.
hwi GetSessionHandle sess;
sess GetProjectHandle prj
prj GetPageHandle pg 1
pg GetWindowHandle win 1
win GetClientHandle cl
cl GetCurveHandle crv 1
crv GetVectorHandle vecx x #taking the horizontal vector
vecx GetParameterizationID # will return c1.x
None.
Keywords
HyperWorks
Tcl
ID
Query
Vector
DataSource
