pltIVector SetDataType
Sets the datatype used by the vector.
pltIVector_handle SetDataType datatype
HyperWorks Tcl Query
This method is only valid for file vectors.
datatype
The name of the datatype used by the vector.
This is dependent on the data file referenced by the vector. This method only changes the filename.
Call the Recalculate method on the parent plot object to update the data.
Success or an error code.
