pltIVector SetReaderTargetVersion
Sets the reader target version of the reader of the data file referenced by the datasource (vector).
pltIVector_handle SetReaderTargetVersion version
HyperWorks Tcl Modify
This command sets the reader target version of the reader which has successfully processed the data file referenced by the datasource (vector).
version
The version value to be set, for example, 13.0 or 14.0.
#Precondition : A curve must be available on the plot client window.
hwi GetActiveClientHandle cl;#Must be a plot client.
cl GetCurveHandle crv 1;#Get the handle of the curve at index 1.
crv GetVectorHandle yvec y;#Possible options are x or y or u or v.
yvec SetReaderTargetVersion 14.0;
0 is returned upon success, or an error code is returned upon failure.
Keywords
HyperWorks
Tcl
DataSource
Vector
Modify
