PEM Portal Homepage
In the PEM Portal homepage, you can select which material pairs to include in investigation either by creating a new search or selecting a previously saved search.
The material pair search can be approached in two ways:
  • Select the required Material, Manufacturer, and Brand under Part 1 and Part 2 sections and click Search. This searches the material pairs in the database based on the applied search filters.
  • Select any one of the criteria either under Part 1 or Part 2 sections and click Search. This searches for all the possible material pair combination available for the selected criteria. Click Reset to reset the selection in all lists.
Saved Search
If a search has been saved in a previous session, it will be visible here. Select the required search you want to review again.
