Motorcycle Telescopic - Rigid and Deformable Strut Rod (Inverted)
In upside down (inverted), as the name suggests, this suspension is fitted in a completely opposite direction. This means the handle yoke is connected to the barrel unit while the sliders are connected to the wheel of the bike. Compared to the regular telescopic fork, this system is stiffer as the tube is larger in diameter at the top to react the bending moments.
Rigid
Deformable
