FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Manage all of the IDs for the entities that you create, and define ID ranges for all of the entities in each Include
file in relation to the full model in order to avoid ID duplication.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
Use the Auto Contacts tool to determine contact interfaces between selections of components or elements. Based on
the user-specified options like proximity tolerance, surface creation method, main surface type, and secondary type,
the tool generates contacts based on set segments or node and element combinations.
