report
Report outputs and visualization configuration.
Settings
advance
true = Advance style report with MultiCPU, false = Normal style report with 1CPU.
Supported values: true
Convert PPT to PDF
Converts PowerPoint slide to PDF file.
avoid_duplicate_slide
true = duplicate slides avoided, #duplicate issues shown under instance, false = all of the issues for single pairs will be reported.
Fullmodel-image
Full model image will be shown in wireframe in all Verification slides at the left top image. This takes additional time for generating wireframe imaged.
Default/Allowed : OFF/ON
imageType-Verification
To reduce slide size the JPG format can selected. By default, the h3d option allows you to view the results in 3D view.
Default/Allowed : h3d/jpeg
visualization settings define configurations related to visualization.
bg
Background colors to be used for creating H3D files and images.
h3d
The background color to be used when creating H3D files.
Supported values: 255, 255, 255, 255, 255 255
jpg
The background color to be used when creating JPG image files.
Supported values: 49, 111, 255, 95, 181 266
color
Default colors for various check results.
comparison
Default colors for comparison check.
master
Color number for Master component.
Supported values: Color Number, ex - 12
slave
Color number for Slave component.
Supported values: Color Number, ex - 6
unmatched
Color number for unmatched entities.
Supported values: Color Number, ex - 33
WT-Calculation
Option to display the weight in the reports. true - will enable the display and false - will disable the display.
Supported values: true or false
WT-Comparison
Option to display the delta weight in the reports. true - will enable the display and false - will disable the display.
WT-Graph
Option to display the weight graph in the reports. true - will enable the display and false - will disable the display.
WT-Graphtype
Option to choose the waterfall graph type. The values 0 / 1 / 2 / 3 represent the available graph types.
Supported values: 0, 1, 2, 3
WT-Scalefactor
Multiplies the weight with the specified multiplication factor.
Supported values: A desired multiplication factor. Default is 1.
intersection
Default colors for intersection test.
master
Supported values: Color Number, ex - 55
slave
Supported values: Color Number, ex - 21
master-intersecting
Color number for intersecting elements on the master component.
Supported values: Color Number, ex - 62
slave-intersecting
Color number for intersecting elements on the slave component.
Supported values: Color Number, ex - 47
transparency
Transparency settings.
intersection
Transparency settings for intersection check.
master
The choice to turn on transparency for the master component. True enables transparency and false makes the component opaque.
slave
The choice to turn on transparency for the main component. True enables transparency and false makes the component opaque.
level
The level of transparency on a scale of 0 to 10. 0 being no transparency and 10 being completely transparent.
Supported values: Number, ex - 3
comparison
Transparency settings for comparison.
level-assembly
The level of transparency on a scale of 0.5 to 7, with 0.5 being high transparency and 7 being less transparent.
Assembly (ON/OFF) converts matched entries into transparency mode in the first page of the PPT (OFF by default).
intersection
Visualization related settings for intersection reporting.
cross
Settings related to Cross.
length
The length of the cross as a percentage of the model length.
Supported values: Percentage, ex - 8
width
The width of the cross as a percentage of the model length.
Supported values: Percentage, ex - 0.15
sphere
Sphere dimension for the sphere.
radius
The radius of the sphere as a percentage of the cross length.
Supported values: Percentage, ex - 2
color
The color to be used for the sphere by specifying the corresponding color number from the palette.
Supported values: Percentage, ex - 3
reportgroup
multiple = Multiple slides in single PPT.
Supported values: single / multiple
spotweld
Setting related to spot weld check reporting.
cross
Settings related to cross.
length
width
sphere
radius
The radius of the sphere as a value in model units.
color
clip
Clip dimensions.
radius
Attribute - TBD.
Supported values: Value in model units, ex - 150
hvp
DO NOT CHANGE.
Supported values: Text Value, ex – HvpLeft, HvpRight
bordercolor
Border color of the HVP title note.
titlefontsize
Title font size.
titlecolor
Title Color.
titlefont
Title Font.
comparisonunified settings:
max-record
Supported values: 50
template
The file name of the MS PowerPoint template to be used for reporting.
Supported values: File name, ex – “Template_compare.potx”
template-sheet
Name given to template.
skip-assembly-slide
Skip the assembly image in the first slide of MS PowerPoint.
skip-thumbnail-slide
Parameter to skip second page of Comparison PowerPoint and Excel report.
skip-thumbnailassemblyimage
Parameter to skip assembly image in Comparison PowerPoint (checkbox).
template-ppt
Path of the power point template.
percentage-sequence
This is the parameter for arranging the order of thumb nail images of components in the PowerPoint.
Supported values:
  • 0 – Default order.
  • 1 – Match percent in decreasing order.
  • 2 – Part IDs in decreasing order.
resultslide
This is the parameter to get the default multiple slides for multi-variant comparison or to get single slide which shows the best match result.
Supported values:
  • Default – Multiple slides are shown.
  • Best match – Best matches for each components are shown from the multiple variants.
threshold_report
This is an intermediate percentage value to be given between threshold value and maximum value. The components having match percent value between threshold and threshold_report value is shown in green color and the components with value between threshold_report and maximum value in gray color.
result-review
Result display setting after comparison check is completed. The following options can be selected to display unmatched entities on graphics.
tempNodes
Displays unmatched area as temp nodes.
tempComps
Displays unmatched area as elements in red color.
tempComps+Node XYZ
Displays unmatched area as elements in red and exports unmatched nodes in a text file working folder.
legend-detailed
Applicable for Quick Comparison flag ON, unmatched elements are shown in red color.
legend-overview
Applicable for Quick Comparison flag ON, unmatched elements are not shown in red color showing high level results.
range-legend-level
Applicable for Quick Comparison flag ON. Comparison legend left tab Ranged's number of levels are controlled by these values. 0 to 100% values are split by these values. An example in case of 30-90% match results exist, 90-30/7=8.57 splits will be shown.
threshold-ranges
Applicable for Quick Comparison flag ON. Comparison legend right tab Discrete's levels are controlled by these values. The accepted value is from 30 to 99.9 with spaces between values.
Default: 50 80 90 (result legend will display 0-30, 30-50, 50-80, 80-90, 90-100. Specific range will be ignored if no results found).
thumbnail-assemblyImageColor
Applicable for quick Comparison flag ON. Part color shown inside the assembly thumbnail image, it is in the 2nd page of the Powerpoint report.
Default: Dark blue.
thumbnail
Text displayed below thumbnail image, supports PID or Part Name. It is in the 2nd page of the Powerpoint report.
Default: PID.
Show unmatched ribs
Parameter to display unmatched surfaces for the Honeycomb kind of Rib pattern. The default is OFF.
Q-Compare
This option can be used if comparison performance is main concern. It reads Base and Variant model data and compares them on the screen. Interface and workflow is similar to default comparison with few limitations.
Assembly-View
If this option is ON, Matched/Unmatched parts color can be controlled for the Assembly images in the summary report. Parts unmatched/matched color can be controlled using these check box color options.
Default: OFF/ON.
Intersection settings are related to reporting for intersection check.
max-slide
Maximum number of slides to be included in the PPT file.
Supported values: Number (for example, 50).
ignore_part_Instance
Ignores part instances from intersection check and report. This is applicable if the number of parts in the model are more then 300.
Default: ON.
ignore_name_Instance
Ignores parts if their Part Names and Part Number are almost the same from intersection check and report. This is applicable if the number of parts in the model are more then 300.
Default: ON.
display_intersection_depth
Displays intersection depth value in a text box inside HyperView player.
Default: OFF.
text-static
You can enter the information.
Supported values:
object: “Text left”
description: “Intersection Check”
object: “Text right”
description: “Answer:”
object: “Info3”
description: “_”
object: “Info4”
description: “_”
object: “Info5”
description: “_”
object: “Info6”
description: “_”
spotweld settings:
max-slide
Supported values: Number,ex-50
text-static
Supported values:
object: “Text left”
description: “Spotweld Check”
object: “Info3”
description: “_”
object: “Info4”
description: “_”
object: “Info5”
description: “_”
object: “Info6”
description: “_”
spot-comparison settings:
max-slide
template
Supported values: File name, ex – “Template.potx”
text-static
Supported values:
object: “Text left”
description: “Spotweld Comparison”
object: “Info3”
description: “_”
object: “Info4”
description: “_”
object: “Info5”
description: “_”
object: “Info6”
description: “_”
freepart settings:
max-slide
template
layout
DO NOT CHANGE.
Supported values: Number, ex – 2
text
description
DO NOT CHANGE.
Supported values: Text Value, ex – “Text1”
project
DO NOT CHANGE.
Supported values: Text Value, ex – “Info1”
id
DO NOT CHANGE.
Supported values: Text Value, ex – “Info7”
date
DO NOT CHANGE.
text-static
Supported values:
object: “Text left”
description: “Connection Check”
object: “Info3”
description: “_”
object: “Info4”
description: “_”
object: “Info5”
description: “_”
object: “Info6”
description: “_”
