Browsers supply a great deal of view-related functionality by listing the parts of a model in a tabular and/or tree-based
format, and providing controls inside the table that allow you to alter the display of model parts.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Combine two or more lines to form a continuous line.
Tip: The more accurate and well defined your
interfaces (geometrical lines) are, the less time you have to spend editing and
updating E-Lines at a later stage. Make sure you have one
Geometrical line per interface.
Select Combine from the guide bar.
Left-click to select lines to combine and click
Combine.
