Delete Lines
Delete required lines from the model.
From the Setup group, click Define Interface > Review / Edit Interfaces.
Figure 1.The guide bar opens.
From the guide bar, click
to define the line length criteria.
Figure 2. -
Click Find.
Tip: If you created lines on all component edges, use the find functionality here to delete all short lines. This can ease the selection of lines at the E-Line creation stage.All lines within the line length range are found.
- Optional:
Select the required lines from the graphics area manually.
The number of lines selected to delete are displayed next to the Line button.
Click
This deletes the selected lines.
