Split Lines
Edit geometric lines.
- Select Split from the guide bar.
- Select a position on a line and click Split.
View new features for HyperWorks 2022.2.
Explore the SnRD Pre-Processing user interface.
Use Setup Group to setup evaluation lines and define loadcases.
Import all data required for the Squeak and Rattle Analysis preparation.
Use the Define Interface tool to create, import, and edit geometric lines.
Delete required lines from the model.
Combine two or more lines to form a continuous line.
Use the Create E-Lines tool to create evaluation lines at component interfaces.
Use the Manage E-Line tool to review and manage E-Lines.
Setup loadcases to solve and extract results.
Use a Variability Study to examine how squeak and rattle risks are affected by manufacturing variations.
Use the Manage E-Points tool to modify local system collectors and evaluation points.
Evaluate Loadcase and export solver deck.
Explore SnRD Post Processing User Interface.
Use of Altair Ziegler SnR Material Database.
ON THIS PAGE
ON THIS PAGE
