HMIN_curve_write()
void HMIN_curve_write(HM_entityidtype id, char * name, char * title, int linetype, int markertype, int color, int width, double scalex, double scaley);
HyperMesh hminlib Function
id
The ID of the curve to be written.
name
The name of the curve to be written.
title
The title associated with the curve.
linetype
The type of line used for the curve:
1 - Solid
2 - Dotted
3 - Dashes
4 - Dash-dot
5 - Long dashes
markertype
The type of marker to be used. Set to 1 for circles, 2 for triangles, or 3 for boxes.
color
The color to be used for the curve.
width
The desired width of the curve.
scalex
The x scale of the curve.
scaley
The y scale of the curve.
After using HMIN_curve_write() to supply information regarding the curve, use HMIN_curve_writepoint() to supply the points of the curve to be transferred.
None.
