HMIN_curve_writepoint()
Writes the points of the curve to HyperMesh.
void HMIN_curve_writepoint(double point1, double point2);
HyperMesh hminlib Function
point1
The x coordinate of the point to be passed.
point2
The y coordinate of the point to be passed.
The function HMIN_curve_write(), must be used before HMIN_curve_writepoint(). HyperMesh is then ready to make the curve with the points supplied in HMIN_curve_writepoint().
None.
