HMIN_load_writeflux()
Writes a flux to hmlib.
void HMIN_load_writeflux(HM_entityidtype id, unsigned char type, HM_entityidtype nodeid, HM_entityidtype systemid, double flux, HM_entityidtype loadcollectorid);
HyperMesh hminlib Function
id
The ID of the flux.
type
The type of the flux, a user-defined value.
nodeid
The ID of the node where the flux is applied.
systemid
The ID of the system in which the flux is applied.
flux
The flux to be applied.
loadcollectorid
The ID of the collector in which the flux is applied.
None.
