HMIN_load_writetraction_nodes()
Writes the tractive pressure applied to an element to hmlib, given the nodes that define the face where the pressure should be applied.
void HMIN_load_writetraction_nodes(HM_entityidtype id, unsigned char type, HM_entityidtype eid, HM_entityidtype nodes[4], HM_entityidtype systemid, double xcomp, double ycomp, double zcomp, double magnitude, HM_entityidtype loadcolid);
HyperMesh hminlib Function
id
The ID of the tractive pressure.
type
The type of the tractive pressure, a user-defined value.
eid
The ID of the element in which the tractive pressure should be applied.
nodes[4]
The nodes that define the face where the tractive pressure should be applied.
systemid
The ID of the system in which the tractive pressure should be applied.
xcomp
The x component of the vector.
ycomp
The y component of the vector.
zcomp
The z component of the vector.
magnitude
The magnitude of the pressure.
loadcolid
The ID of the load collector where the tractive pressure should be placed.
None.
