Model Checker Plots
The model checker plots module highlights and captures the failed checks of the report type plot from the model checker tool.
View new features for HyperWorks 2022.
Create an assembly structure from a .csv file definition.
A powerful tool for manual/automatic report creation using the model summary report template (.tpl) file. This tool provides a simplified and consolidated approach for report creation with one click and by define your own report structure.
Modules are used to perform specific operations in a report in automated ways and provide the output in the prescribed format per module logic.
Select export and module settings.
Capture a dynamic view of the model, including display options.
Explore the GeoD user interface.
