Part Summary
- Component High level Info
 - Component with Min Max ID Details
 - Component Mass Highlights
 - Component COG Data
 - Component MOI Data
View new features for HyperWorks 2022.
Create an assembly structure from a .csv file definition.
A powerful tool for manual/automatic report creation using the model summary report template (.tpl) file. This tool provides a simplified and consolidated approach for report creation with one click and by define your own report structure.
Modules are used to perform specific operations in a report in automated ways and provide the output in the prescribed format per module logic.
Select export and module settings.
Capture a dynamic view of the model, including display options.
Explore the GeoD user interface.
