Element Summary
The element summary module generates two table outputs with the type, config and count of all 1D, 2D and 3D elements. The table names are Elements 1D Count and Elements 2D 3D Count.
View new features for HyperWorks 2022.
Create an assembly structure from a .csv file definition.
A powerful tool for manual/automatic report creation using the model summary report template (.tpl) file. This tool provides a simplified and consolidated approach for report creation with one click and by define your own report structure.
Modules are used to perform specific operations in a report in automated ways and provide the output in the prescribed format per module logic.
Select export and module settings.
Capture a dynamic view of the model, including display options.
Explore the GeoD user interface.
ON THIS PAGE
ON THIS PAGE
