Model Summary
A powerful tool for manual/automatic report creation using the model summary report template (.tpl) file. This tool provides a simplified and consolidated approach for report creation with one click and by define your own report structure.
This report covers the following aspects related to the model:
- Isometric view
 - Top view
 - Front view
 - Left-side view
 - Pre-defined
 - Global Model Summary
- Entire model high level entity count
 - Entire model units
 - Entire model mass information
 - Entire model MOI using COG as center
 - Entire model COG information
 - Part Summary
- Component high level information
 - Component with min max ID details
 - Component mass highlights
 - Component COG data
 - Component MOI data
 - Material Summary
- Material isotropic MAT1 details
 - Material isotropic MAT4 details
 - Material anisotropic MAT2 details
 - Material orthotropic MAT8 details
 - Property Summary
- Property information with type and ID
 - Elements Summary
- Elements 1D count
 - Elements 2D 3D count
 - 2D mesh quality statistics table
 - 2D mesh quality statistics plot
 - 3D mesh quality statistics table
 - 3D mesh quality statistics plot
 - Ply Orientation
- Information of model
 - Model thickness in mm plot
 - Model material and property IDs and plies "0°, 45°, -45°, 90°"
 - Shell Summary
 - Entire model shell thickness summary
 - Model Checker Summary
- Model Checker ERROR table
 - Model Checker WARNING table
 - Model Checker INFO table
 - Failed Checks tables
 - Model Checker Plots
- Component with solids and shells
 - Orientation vector along axis vector
 - RBE3 elements are collinear
 - Duplicate 1D/2D/3D elements
 - Free nodes in the model
 - Coinciding G1 and G2 grid points
 - Element Quality Plots
- Aspect ratio 2D/2D
 - Chordal deviation 2D
 - Coordinate systems
 - Free edges
 - Free faces
 - Normal
 - Element offset 1D
 - Element coordinate system
 - Node coordinate system
 - Jacobian 2D/3D
 - Volume aspect ratio 3D
- Interactive Mode
 - The Report Browser is used to create, execute and export document and presentation reports.
 - Default Mode
 - Generate pre-defined model summary report.
 - Model Checker Report
 - Define report group enables you to perform report actions with one click.
 - Aerospace Model Summary Report Modules
 - Modules are used to perform specific operations in a report in automated ways and provide the output in the prescribed format per module logic.
 - Preferences
 - Modify the main document and select the report template.
 - Custom Tasks
 - Custom tasks in report generation.
 - Record View Tool
 - Dynamic image capture tool.
