Default Mode
Generates the model summary report by a pre-defined reporting structure (template file). Default mode provides a quick export to get the model summary.
- Open/import an existing HyperMesh model.
 - From the menu bar, click Aerospace > Report > Model Summary > Default.
 - Select the report template file with a pre-defined reporting structure. By default the model summary report template is loaded.
 - Select the export directory path for the Report File.
                Click Preferences to select export and module
                    settings.
- Report Master Document: Select a Word document. By default the Altair document is selected.
 - Element Quality Criteria: Select a quality criteria file for the module.
 - Numeric Format: Define the numeric format and the precision value to the entire report.
 - Model Checker Checks Type: Select the checks export type for module model checker summary.
 - Click OK to save all of your preferences.
                Click Export.
                The model summary report with your selected preferences and settings is exported. The progress is shown.
Figure 1. - Click Cancel to exit the model summary report.
