Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
Auto Contactsツールを使用して、選択したコンポーネント同士または要素同士の接触面を決定します。このツールでは、ユーザー指定のオプションに応じて、セットセグメントまたは節点と要素の組み合わせに基づく接触が作成されます。このユーザー指定のオプションとして、近接トレランス、サーフェス作成法、メインサーフェスタイプ、セカンダリタイプなどがあります。
Group parts based on AI code and shape-based approach.
After the check, groups are created under the Partブラウザ/Part
Set Browser. To execute the match, parts are mandatory. Select the root part from
the Verificationブラウザ or the Comparisonブラウザ and run Match.
From the Verificationブラウザ/Comparisonブラウザ, right-click and select Parts > Match from the コンテキストメニュー.
図 1.
From the Method drop-down menu, select either AI (for AI
based grouping) or Shape (for comparison based grouping).
Shape based comparison is slower than AI based part grouping but the quality is
better.
図 2.
In the Similarity (%) field, type the desired same shape match%. The default is
50%.
In the Tolerance field, type the search tolerance to use to find matching
entities. The default is 0.1mm.
In the Max Area field, type the maximum area to search. Parts will be organized
under FilteredBig_Data_Group if the total area of the part is greater than this
value.
In the Min #Surface field, type the minimum number of surfaces to use. Parts
will be organized under Filtered_SmallData_Group it the total area of the part
is less than this value.
Parts will be organized under Unprocessed_Group if the parts do not have the
same shape or are unable to be processed by the AI or Shape method. Similarly,
parts will be organized under MultiSoldi_Group if the parts contain multiple
solids.
Click Run.
Part Set name considers names from Part Name and Part Number. In
addition, filtered data and unprocessed data are displayed in the Partブラウザ. 図 3.
