Configure Parts
Configure any part.
- From the Verificationブラウザ, right-click and select from the コンテキストメニュー.
- Select the Data Type from the drop-down list.
- Enter or browse for the Representation path.
- Select the FE or CAD type from the drop-down list.
- Select the new path for Representation folder.
- Select the base configuration.
- Select the Part Name or Part ID from the drop-down list.
- Click Close to exit the configuration.
- Click Check to check and update the Representation.
- Click Update to update the Representation with new settings.
- Click Import to import the Representation.
