/INISHE/SCALE_YLD or /INISH3/SCALE_YLD
Block Format Keyword This option is used to set a scale factor for yield stress per element for shells.
| /INISHE/SCALE_YLD/unit_ID or /INISH3/SCALE_YLD/unit_ID | |||||||||
| shell_ID | nb_integr | npg | |||||||
| Alpha_ij | |||||||||
Definition
| unit_ID | Optional unit
identifier. (Integer, maximum 10 digits) |
| shell_ID | Element
identifier. (Integer) |
| nb_integer | Integration point
number through the thickness as defined in the property
definition of this element. (Integer) |
| npg | Number of surface
quadrature points.
| Alpha_ij | Yield stress scale
factor of integration point. i in surface quadrature (npg) j in thickness direction (nb_integer) (Real) |
In this example use:
/PROP/SHELL Ishell =12 ≥ must set ngp=4 (then i=4 in Alpha_ij).
/PROP/SHELL/2
shell prop
# Ishell Ismstr Ish3n Idrill
12 0 0 0
# hm hf hr dm dn
0 0 0 0 0
# N Thick Ashear Ithick Iplas
3 1 0 0 0
/INISHE/SCALE_YLD
# shell_ID nb_integr npg
1 3 4
# scale_yld
1.20
.80
1.20
1.20
.80
1.20
1.20
.80
1.20
1.20
.80
1.20
#enddataComments
- The nb_integr must be equal to the number of integration points given in the shell property.
- The npg must be set according to the formulation which is used in the shell property.
- The number of values
alpha_ij given must be equal to
.For i = 1
- Alpha_11 for integration point = 1
- Alpha_12 for integration point = 2
- Alpha_1j for integration point = j
For i = 2- Alpha_21 for integration point = 1
- Alpha_22 for integration point = 2
- Alpha_2j for integration point =j
For i = npg- ...
