/INISHE/EPSP_F or /INISH3/EPSP_F
Block Format Keyword Describes the initial plastic strain for a shell in each integration point.
| /INISHE/EPSP_F/unit_ID or /INISH3/EPSP_F/unit_ID | |||||||||
| shell_ID | nb_integr | npg | Thick | ||||||
| p1 | p2 | p3 | p4 | p5 | |||||
Definition
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| shell_ID | Element
identifier (Integer) |
| nb_integr | Integration point number
through the thickness Must be equal to the number of integration points given in the shell property. (Integer) |
| npg | Number of surface
quadrature points. Must be set according to the formulation, which
is used in the shell property.
(Integer) |
| Thick | Shell thickness. Will be
used instead of the thickness given into property or in the shell
definition. (Real) |
| p1 | First plastic
strain (Real) |
| p2 | Second plastic
strain (Real) |
| p3 | Third plastic
strain (Real) |
| p4 | Fourth plastic
strain (Real) |
| p5 | Fifth plastic
strain (Real) |
- For npg = 0 or 1, this reduces to the list of plastic strain values from the first point to the nb_integrth one.
- Values of
Epsp are given in sequence Line 4 in the following order:
- For each Integration point through the thickness j=1, nb_integr
- For each surface quadrature point i=1,npg
- Input pi,j
