2020.1 API Programmer's Guide
Elements to Solvermasses
The LS-DYNA keywords *ELEMENT_INTERTIA, *ELEMENT_INERTIA_OFFSET, *ELEMENT_MASS, *ELEMENT_MASS_NODE_SET, *ELEMENT_MASS_PART and *ELEMENT_MASS_PART_SET have been mapped from the element entity to the solvermass entity. See the solvermasses data names documentation for more details.
Scripts that created or queried the element entity for this keyword must be updated to use the solvermass entity. Note that solver ID pools are no longer required with this new entity type as well. Below are a few examples.
*createentity solvermass config=105Multiple child masses can be
created by created by adding nodes to the parent
mass:*setvalue solvermass id=1 entityids= {nodes 1 2 3}To assign
masses all at once:*setvalue solvermass id=1 masses={0.2 0.0 0.0}*createentity solvermass config=102*createentity solvermass config=103*createentity solvermass config=104*createentity solvermass config=106*createentity solvermass config=106 offsetoption=true*createentity solvermasses config=106
set id [hm_latestentityid solvermasses]
*setvalue solvermasses id=$id compxx=0.05*setvalue solvermasses id=$id setid={sets 2}*setvalue solvermasses id=$id STATUS=2 finalmass=0.004HWAT
package require hwatNew Commands
- Comparison
- Composites
- Data Names
- General/Core
- Geometry
- HMASCII
- Meshing
- Modules/Parts
- Morphing
- Multiple Models
- Template Commands
Modified Commands
The following commands have modified behavior that potentially require script updates:
- Meshing
- hm_holedetectiongetholedetails - Resolved an issue where FE holes would always return the hole type as general.
- Comparison
- hm_getmatching - Added new options compareType, encoding_algorithm, sphhar_bandwidth, sphhar_fallof, sphhar_radii and sphhar_resolution. Added new searchMethod ByEncoding.
- Composites
- *laminaterealizewithoptions - Option reserved1 has been upgraded to the public option create_sequence
- Data Names
- All entities now have a solverkeyword data name.
- contactgroups - Added new data names adjust_to_clearance, adjust_to_interference, adjust_type, adjust_val, adjust_val_real, auto_shrink, clearance, constraint_type, constraint_type_explicit, critical_penetration, formulation, friction_id, initial_state, initial_state_tol, interference, penalty_scale_factor, penalty_scale_factor_explicit, reference_value_ratio, search_angle, search_depth, search_gap, search_width, surface_behavior, tying_type, type and use_thickness. Added new config value 601.
- ddvals - Added new data names ddrangemax, ddvaluesmax, drangefrom, drangeing, drangeto and valuesdouble.
- designpointmethods - Added new category value beam.
- designpointsets - Added new data names beamtype and outputtableids. Added new config values 1 and 2.
- failures - Added new data names C0, f_cutoff, f_flag and xscale.
- frictions - Added new data names c1_2, c2_2, c3_2, c4_2, c5_2, c6_2, e_coef, elastic_slip, fric_2, friction, friction_format, friction_style, friction_table, friction_type, Grpart_Part_Type, Idor, iorthmax_shear, maxshear_format, maxshear_style, maxshear_table, n_orient, phi, slip_tolerance, skew_id, vis_f_2, vx, vy and vz. Added new config value 601.
- interfacelinkings - Added new config values 104 and 105 and entityid support for config 105. Added new data names fx, fy, fz, localflag, locnode, locsystem, usecordnate and usenode.
- laminates - Added new data name sequenceids.
- modules - Added new data name excludeshowhidestate.
- plies - Enumerated the values for the type data name.
- positions - Added new data names idoplist and oplis_selection.
- responses - Added new data names maximumfrequency, minimumfrequency and modenumber. Added new response values 9, 10 and 11.
- rigidwalls - Added new data names HEIGHT, NSEGS and VL.
- solvermasses - Added new config values 101-106. Added new data names componentid, compxx, compxy, compxz, compyy, compyz, compzz, csid, curveid, distribution, finalmass, location_unit_solvermass, nodalgroupid, nodeid, offsetoption, totalmass, xoffset, yoffset and zoffset.
- structuralproperties - Added new config values 100 and 500. Added new data names sebeamsect, sematerial and tableid. Added length support for config 100.
- General/Core
- hm_getvalue - Added new options metadata_value, metadata_value_count, metadata_value_ids and metadata_value_type.
- hm_framework - getuserprofile and loaduserprofile are now supported in batch mode.
- *appendmark/*createmark/hm_appendmark/hm_createmark - Added new methods "by subsystem", "by subsystem id" and "by subsystem name".
- *createautoddp - Added new autoddptype values 1 and 2.
- *createentity - Added new option modelname.
- *detectandcreateface2facecontacts - Added new optional argument copy_tolerance_to_contact.
- *setoption/hm_getoption - Added new options geometry_parasolid_boolean and pr_prefix_basename_suffix_based_name_pairing.
- *rundesignmethod - Added new options columnLabels, debugInfo, loadcaselist, logfileInfo, tableInfo, targetentitymark and targetentitytype.
- *setvalue - Added new option modelname. Added support for <name>=<value> for metadata.
- Geometry
- *create_tube_midline - Added new optional argument tube_ends_mark.
- Graphics/GUI
- hm_getdirectionpanel - Added new option node_coordinates.
- hm_getplanepanel - Added new option node_coordinates.
- *plotmassdistribution - Added support for LS-DYNA config 105 (nodes).
- Meshing
- hm_measureshortestdistance - Added support for elements to entity_type1 and entity_type2.
- hm_measureshortestdistance2 - Added support for elements to entity_type.
- *align1delemsbysystem - Added new options angledeviation , vectorx, vectory, vectorz, xcomp, ycomp and zcomp. Added new align value vec.
- *createelements1d - Added new option orientvec. Clarified the behaviors for useshell.
- *line_mesh_decimator - Added new option ConsiderEdgeConformal2DElems.
- *midmesh_extract - Added new options DefeatureRibsWidth, DefeatureRibsWidthFactor and StepOffsetMode. Deprecated FlattenConnections=2.
- *midmesh_repair - Added new mode values AlignEdgeToMidOfLines and AlignToMid. RepairFace now reevaluates created sets for changes. Added new SplitByNodeEdge mode value 4 and new option SplitPoint.
- *setusefeatures - Added new mode values 8 and 9.
- *tetmesh - Added new parameter shell_dev to the pars string. The tet string parameters max_size, min_height, and min_size are now active optimization targets, instead of just passive split constraints. Multiple criteria are now allowed for regular tetra meshing.
- Multiple Models
- *addnewmodel - Added new optional argument read_only.
Deprecated Commands
- Morphing
- *morphmapedgestonodesoffset - Use *morphmapedgestonodelistoffset instead.
- *morphmaptonodesnodesoffset - Use *morphmaptonodelistvecoffset instead.
- *morphmaptonodesvecoffset - Use *morphmaptonodelistvecoffset instead.
