*contactbehaviors()
Creates a contactbehavior in HMASCII format.
*contactbehaviors (id, name, color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the contactbehavior.
name
The name of the contactbehavior.
color
The color of the contactbehavior. Valid values are 1-64.
To create a contactbehavior with ID 100, name "my-entity", and color 1:
*contactbehaviors(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2020.1
