*outputblocks()
*outputblocks (id name type)
HyperMesh HMASCII Command
id
The ID of the outputblocks.
name
The name of the outputblock.
type
Set to "nodes" or "elements" to define the type of the outputblock being created.
Use the *outputblockid() command to place entities in the outputblock.
None.
