*plotcontrols()
Creates plotcontrols in HMASCII format.
*plotcontrols (id, name, color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the plotcontrol.
name
The name of the plotcontrol.
color
The color of the plotcontrol. Valid values are 1-64.
To create a plotcontrol with ID 100, name "my-entity", and color 1:
*plotcontrols(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2021.2
