*subsystems()
Creates a subsystem in HMASCII format.
*subsystems (id, name, color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the subsystem.
name
The name of the subsystem.
color
The color of the subsystem. Valid values are 1-64.
To create a subsystem with ID 100, name "my-entity", and color 1:
*subsystems(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2020
