*connectorgroups()
Creates a connectorgroup in HMASCII format.
*connectorgroups (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the connectorgroup.
name
The name of the connectorgroup.
color
The color of the connectorgroup. Valid values are 1-64.
To create a connectorgroup with ID 100, name "my-entity", and color 1:
*connectorgroups(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2019
