*fields()
Creates a field in HMASCII format.
*fields (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the field.
name
The name of the field.
color
The color of the field. Valid values are 1-64.
To create a field with ID 100, name "my-entity", and color 1:
*fields(100,"my-entity",1)
Incorrect usage results in an import error.
