*joint_spherical()
*joint_spherical() (id type node1 node2 propertyid orientation orientid1 orientid2)
HyperMesh HMASCII Command
id
ID of the element.
type
Type of the element.
node[1,2]
The node IDs of the element.
propertyid
The ID of the element’s property.
orientation
The orientation associated with the element. Use:
0
None
1
Systems
2
Nodes
orientid[1,2]
The system or node IDs associated with the element.
This command must follow a *component() command.
None.
