*titleanchor()
*titleanchor (anchorpoint anchorangle distance type entityid)
HyperMesh HMASCII Command
anchorpoint
Identifies the corner of the title that is used as the anchor point. Set to 0, for lower left; 1, for upper left; 2, for upper right; and 3, for lower right.
anchorangle
The angle relative to a vertical line running through the entity and the title lead.
distance
The distance from the entity to the anchor point.
type
The name of the entity to which the title is attached.
entityid
The ID of the entity to which the title is attached.
None.
