*metadata_integer_array()
Creates integer array metadata in HMASCII format.
*metadata_integer_array (entity_type,entity_id,"name",size,value1,value2,...,valueN)
HyperMesh HMASCII Command
entity_type
An integer indicating the type of entity the metadata is attached to. A value of undef indicates attachment to the database itself.
entity_id
The ID of the entity the metadata is attached to. Ignored if entity_type is undef.
size
The number of values in the array.
values
The integer values assigned to the metadata. Each value is separated by a comma. There must be size total values.
To create integer array metadata attached to element ID 100, with name "my-integers" and the values 3, 4 and 5:
*metadata_integer_array(2,100,"my-integers",3,3,4,5)
Incorrect usage results in an import error.
