*sections()
*sections (id,name,color)
HyperMesh HMASCII Command
Creates a section in HMASCII format.
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the section.
name
The name of the section.
color
The color of the section. Valid values are 1-64.
To create a section with ID 100, name "my-entity", and color 1:
*sections(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2022
