*noisecontroltreatments()
Creates a noisecontroltreatment in HMASCII format.
*noisecontroltreatments() (id,name,color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the noisecontroltreatment.
name
The name of the noisecontroltreatment.
color
The color of the noisecontroltreatment. Valid values are 1-64.
To create a noisecontroltreatment with ID 100, name "my-entity", and color 1:
*noisecontroltreatments(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2022
