*loadcollector()
Creates a load collector in HMASCII format.
*loadcollector (id,"name",color)
HyperMesh HMASCII Command
id
The ID of the load collector.
name
The name of the load collector.
color
The color of the load collector. Valid values are 1-64.
To create a load collector with ID 100, name "my-loadcol" and color 1:
*loadcollector(100,"my-loadcol",1)
Incorrect usage results in an import error.
