*members()
Creates a member in HMASCII format.
*members (id,name,color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the member.
name
The name of the member.
color
The color of the member. Valid values are 1-64.
To create a member with ID 100, name "my-entity", and color 1:
*members(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2022
