*constrainedrigidbodies()
Creates a constrainedrigidbody in HMASCII format.
*constrainedrigidbodies (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the constrainedrigidbody.
name
The name of the constrainedrigidbody.
color
The color of the constrainedrigidbody. Valid values are 1-64.
To create a constrainedrigidbody with ID 100, name "my-entity", and color 1:
*constrainedrigidbodies(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
14.0
