*seamsubsystems()
Creates a seamsubsystem in HMASCII format.
*seamsubsystems (id, name, color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the seamsubsystem.
name
The name of the seamsubsystem.
color
The color of the seamsubsystem. Valid values are 1-64.
To create a seamsubsystem with ID 100, name "my-entity", and color 1:
*seamsubsystems(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2021.2
