*seasubsystems()
Creates a seasubsystem in HMASCII format.
*seasubsystems (id, name, color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the seasubsystem.
name
The name of the seasubsystem.
color
The color of the seasubsystem. Valid values are 1-64.
To create a seasubsystem with ID 100, name "my-entity", and color 1:
*seasubsystems(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2021.2
