*resultsimulations()
Creates resultsimulations in HMASCII format.
*resultsimulations (id, name, color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the resultsimulation.
name
The name of the resultsimulation.
color
The color of the resultsimulation. Valid values are 1-64.
To create a resultsimulation with ID 100, name "my-entity", and color 1:
*resultsimulations(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2021.2
