*rigidlink()
Creates a rigidlink element in HMASCII format.
*rigidlink (id type independentnode dof dependentnodes)
HyperMesh HMASCII Command
id
The ID of the element.
type
The type of the element.
independentnode
The ID of the independent node.
dof
The degrees of freedom.
dependentnodes
The number of dependentnodes contained in the following *dependentnodes() entry.
A *dependentnodes() description must immediately follow.
None.
