*curve()
*curve (id name title xkind xpath xtype xreg xcomp ykind ypath ytype yreg ycomp linetype markertype color width scalex scaley)
HyperMesh HMASCII Command
id
The ID of the curve (must be unique).
name
The name of the curve.
title
The title of the curve.
xkind
xpath
xtype
xreg
xcomp
ykind
ypath
ytype
yreg
ycomp
linetype
The line style used to draw the curve line. Must be one of the following values:
  • 0 - no line
  • 1 - solid line
  • 2 - pattern1
  • 3 - pattern2
  • 4 - pattern3
  • 5 - pattern4
markertype
The marker type used to draw points on the curve. Must be one of the following values:
  • 0 - no marker
  • 1 - circle marker
  • 2 - triangle marker
  • 3 - square marker
color
The color of the curve. Refer to the color variable chart.
width
The width of the curve line in pixels (either 1 or 3).
scalex
The x axis scale factor.
scaley
The y axis scale factor.
The points making up a curved area are defined using the *curvepoint() command described below. Points must immediately follow the *curve() definition. Curves must be defined before plots.
None.
